Best place to buy a gold chain from?
Enquiring for a friend with a Z1B.
What the best make of chain these days and where is the best place to buy?
Gary
Gary
Re: Best place to buy a gold chain from?
garyd wrote:Enquiring for a friend with a Z1B.
Gary
The pawn brokers sell Gold cheaper than High St Jewellery shops.
On a sensible note, MandP direct are very reasonable. Or try Debbens.
Warning I have a Renthal chain fitted to my Z1000 and over the winter the gold colour discoloured - so avoid Renthal.
DID X ring chain is what I will probably buy next time.
Adrian.
bigrocketrider
bigrocketrider
http://stores.ebay.co.uk/Brooks-Barn-Mo ... 7675.l2563
Paste the above into your search drive. This is their shop. Hopefully it will work as I am not very sharp with the computer.
- firyembers
- Custard Creem
201048770042
This one cheap as chips,i will buy one to try but i neither ride many miles so longegivety and how it stands up unknown.
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
- harrythemagnum
firyembers wrote:201048770042
I think I've tried one of these, Chinese, used it to make sure of my alignment after a wider wheel conversion on my ZRX, rather than wrecking an expensive chain if it was out, I didn't look after it, lasted a couple thousand hard ridden miles ok, but went bad really quickly at the end.
What a wonderful philosophy you have,
Gary
I personally use DID chains - had a cheap chain 'let go' some years back, luckily didn't do any damage but have seen some who weren't so lucky that its happened to.
Guess its a case of buy what you can afford.
Most Bike shops should be able to supply a decent chain if you know the pitch and number of links ie 530 x 122
Debbens - http://www.debben.co.uk/530xring.html
Zpower - https://www.z-power.co.uk/merchantmanag ... cts_id=886 (630 chain)
Hope this is of some use
Wots up DOHC
- steve bowdler
- firyembers
- Custard Creem
steve bowdler wrote:firyembers wrote:201048770042
Hi mate could always wear it round your neck out in Venezuala or even Splott when you get back home
Ha Ha..Exactly,especially after i thrashed it for a 1000 miles maybe..be really loose..Not bother much with Splott,more in the Roath upper class area
Drinks and ride in August ??
