Harris Magnum I
#61 PostAuthor: Pigford » Sun May 18, 2014 3:11 pm
Had another little detail to sort - thanks for the link Bear.....
Monster Craftsmen are ace - they shipped from the USA and it came to a total of £89 all-in...... they are smart and even made sure the item was tax friendly :wink: I'd highly recommend them!!!!!
Now it's nice & sunny - took the bike for a longer run - 50 miles round trip to West Bay :P
Plenty of bikes - not much to shout about apart from the one on the far left .....
...... note the bloke taking a good look even if his bird was getting in the way :lol:
Magnum1
#62 PostAuthor: Magnum1 » Mon May 19, 2014 4:18 pm
I've been looking at the chain tensioners, what size chain are you running? Is it a 530?
Rod
HowieD
#63 PostAuthor: HowieD » Mon May 19, 2014 6:07 pm
I think the tax friendly thing is my fault 'cos mine got stitched up for £22 import duty on its way in :(
edited to correct the Duty to pay after re-reading my thread !!
CD185, Maggot, Z1-R, Horace
#64 PostAuthor: Pigford » Tue May 20, 2014 4:05 pm
Magnum1 wrote:I've been looking at the chain tensioners, what size chain are you running? Is it a 530?
Rod
Rod - yes 530 - 19t front & 42 rear :wink:
HowieD - whatever the cause - saved me a few quid :twisted:
Magnum1
#65 PostAuthor: Magnum1 » Tue May 20, 2014 4:30 pm
Thanks for that, sorry, just one more question; I see you adapted the tensioner to a bracket. Is that because it won't fit around the cross member?
Rod
#66 PostAuthor: Pigford » Tue May 20, 2014 5:53 pm
Magnum1 wrote:Thanks for that, sorry, just one more question; I see you adapted the tensioner to a bracket. Is that because it won't fit around the cross member?
Rod
Yep - think they sent the wrong diameter - BUT theres sweet FA room for it on the frame tube anyhow as the brazing is in the way :roll: It's fixed to the sidestand cross member so easily removed.
Magnum1
#67 PostAuthor: Magnum1 » Wed May 21, 2014 3:52 pm
Right o, cheers
#68 PostAuthor: Pigford » Fri Jun 13, 2014 2:07 pm
I've now got hold of some tough polypropylene 9mm sheet ....
...and Araldited some of it as a slider.....
So I'll see how that goes :roll:
Also got an R1 hugger off eBay (£10) and it does the job....
AND.............. got some more jets off Allens Performance - pilots & mains - arrived next day (all stuff off the shelf - in stock) so can do some more fine tuning :shock:
#69 PostAuthor: Ginger Bear » Fri Jun 13, 2014 2:13 pm
Looks like a plan Piggy.
I'd be tempted to countersink the top slider & screw it to the swinger as well. If it comes off & gets stuck between the chain & front sprocket you'll be toast. :ek And we don't want that. :no :no
# 104
firyembers
Custard Creem
#70 PostAuthor: firyembers » Fri Jun 13, 2014 3:44 pm
don't be tempted do it,it will not last 5 mins i suggest,not even to the local shop.
I did the same and used some 4mm csk screws...
the consequences are dire.
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
#71 PostAuthor: Pigford » Fri Jun 13, 2014 4:47 pm
firyembers wrote:don't be tempted do it,it will not last 5 mins i suggest,not even to the local shop.
:evil: Oh well - worth a try :!:
#72 PostAuthor: Ginger Bear » Fri Jun 13, 2014 6:36 pm
That might just 'Save your Bacon' Piggy. :up
I can help you out with a couple of Rivnuts if there's not enough meat there, I'm guessing there should be plenty to tap a decent M6 thread.
# 104
#73 PostAuthor: Pigford » Fri Jun 13, 2014 7:17 pm
Cheers lads - I've got the kit - will add a screw or 2 before the test run :wink:
Is Vic There
#74 PostAuthor: Is Vic There » Fri Jun 13, 2014 9:04 pm
Great idea mate, great idea for additional screws as well.
Magnum1
#75 PostAuthor: Magnum1 » Sat Jun 14, 2014 8:46 am
This issue has always been a problem on the Harris', especially with a round tube swing arm. I've tried all sorts of bodges. Now I'm thinking a liquid based resin that can be applied to make a mould could be the way to go. That way it could be enclosed and bolted together in two halves. Or, just apply a load of it in layers straight on the the arm.
Any thoughts?
