Bloody annoying oil leak...
Got a small but annoying oil leak at the rev counter drive on my Z1000 - it leaks down the cable then drips off, it's very slight but when you're riding it blows off and goes all over the exhaust downpipes. I'm thinking it's the O ring on the drive, although that's between the head and drive and the oil's getting into the cable not coming out round the edges, so is it possible a worn drive? Anyone had this before and what was it? I guess oil shouldn't be coming out there as there's no O ring to seal the cable?
replace the o ring on the drive housing also the oil seal. make sure the drive gear shaft is perfectly smooth where it comes through the oil seal . fit one of these between the cable & the drive housing
http://www.cmsnl.com/kawasaki-1977-kz65 ... 2f16fldVGQ
- steve bowdler
I have been looking at this with the extra seal
http://www.ebay.co.uk/itm/371021916263? ... EBIDX%3AIT
- steve bowdler
Hinckley wrote:I'm using one of these - no leaks
https://www.z-power.co.uk/merchantmanag ... ts_id=1134
That is better value , delete the other one from my watch list now
