Cylinder studs
Cylinder studs
Hi Guyz, does anyone have two short cylinder studs M10 x 158. To replace those damaged during removal on my Z1B. Anything usable will be ok, can replate if not too pitted/corroded
Thanks Dave
Thanks Dave
z1bman wrote:part no 92004- 1002 i a 10mm x 190 stud ? 92004- 1040 is a 10mm x158 stud + they are the same as a z900 a4
if you need to contact cradley 01384 633 455
Just recieved the studs from Cradley. Unfortunately that part Number stud length is actually more like 180mm total.
I think the 158mm length quoted on the parts list and on the discription refers to the length of the stud above the crankcase after it is screwed in.
