1984 gpz11 s/arm ?
snotie1965
1984 gpz11 s/arm ?
#1 PostAuthor: snotie1965 » Mon Apr 14, 2014 5:10 pm
I was adjusting my chain yesterday (sun 13th) on my gpz1100 uni-trak,and when i re-tightened the two 8 mm allen bolts to lock the adjusters in, one of them snapped ! so i thought F£ck ! but i have a spare s/arm in the lock-up :) BUT the one off the slightly newer gpz11 ut has a smaller swing arm bolt ,so is not a straight swap :(
Has anyone else come across this ? and would it be possible (safe) to have a collar made up to put into my frame ? it would only be to make up 2mm difference ,the other side is the same ?
I thought i would ask on here before i take both arms to the local engineering shop ?
Or has anyone a spare s/arm going with the larger s/arm bolt (16.8mm) the smaller one is (14.8mm) .Any help would be much appreciated ,i need it sorted before the rain starts again !!!!
FER
Auld Heedyun
#2 PostAuthor: FER » Mon Apr 14, 2014 5:41 pm
Would it not be easier to remove the broken 8mm bolt ?
fer
snotie1965
#3 PostAuthor: snotie1965 » Mon Apr 14, 2014 6:15 pm
FER wrote:Would it not be easier to remove the broken 8mm bolt ?
fer
No the bolt did not break the s/arm cracked where the bolt goes through ?
FER
Auld Heedyun
#4 PostAuthor: FER » Mon Apr 14, 2014 6:17 pm
Ooops !
fer
steve.w
#5 PostAuthor: steve.w » Mon Apr 14, 2014 7:13 pm
the a1 and a2 swingarms are different .. :wink: :wink:
snotie1965
#6 PostAuthor: snotie1965 » Mon Apr 14, 2014 7:27 pm
steve.w wrote:the a1 and a2 swingarms are different .. :wink: :wink:
I did not know that until today when i had both of them on the bench !
Do you think that a insert collar ,bush type thing could be made and then use that in the frame ? the other end is the same ,or should i just try and source another s/arm ?
steve.w
#7 PostAuthor: steve.w » Tue Apr 15, 2014 5:13 am
yeh thatll work..but can u not just swap bearings ..??
snotie1965
#8 PostAuthor: snotie1965 » Tue Apr 15, 2014 6:39 am
no , they are different sizes , i found another s/arm on ebay £30 delivered ,and it is the same size as my original ,so if the bearings/bushes are shagged i can swap them ,chuffed .....
