Fuel tap configuration
tobro
#1 PostAuthor: tobro » Thu Apr 10, 2014 12:42 pm
Can anyone please remind me of the hose routing for the vacuum hose on the fuel tap of my Z1. Where does this attach to the carbs?
My bike is a recently overhauled, with 29mm Mikuni smoothbores and I am struggling to recall this information. :oops:
Life is a game - The one with the most toys at the end wins!
#2 PostAuthor: z1bman » Thu Apr 10, 2014 1:49 pm
z1.s do not have a vacuum tap. but if you have fitted one you can use one of the vacuum take off's on the bottom of the inlet manifold rubbers
the carb below are 26mm from a z650 the black hose on the left the smaller one is where the vacuum take of is
tobro
#3 PostAuthor: tobro » Thu Apr 10, 2014 2:11 pm
Many thanks Z1bman. You have no idea how much that little bit of info means!
I bought the bike as a partly completed restoration a couple of years ago and have been chasing a misfire since (see my previos posts for details) Think I may have just had a eureka moment! Fingers crossed. :D
Yellow
#4 PostAuthor: Yellow » Thu Apr 10, 2014 6:04 pm
z1bman wrote:z1.s do not have a vacuum tap. but if you have fitted one you can use one of the vacuum take off's on the bottom of the inlet manifold rubbers
Hi z1bman,
Can the accelerator pump on them carbs be done away with?
Is it just a matter of replacing the float bowls or is their more involved?
Cheers.
#5 PostAuthor: z1bman » Thu Apr 10, 2014 6:22 pm
Hi z1bman,
Cheers.
yes you can just replace the float chambers
Yellow
#6 PostAuthor: Yellow » Sat Apr 12, 2014 4:55 pm
Thanks z1bman...
