I've tried getting another carb body but all the ones I've found are the '73/Z1A type with the larger ribs. I'd really like to repair this carb body so I'm looking for suggestions.
Here's the broken bit:
Ideas I've had so far (comment and suggestions very very welcome):
A) Epoxy (JB Weld) glue it back together (the break is such that the parts locate back together nicely) and reinforce around the outside with more epoxy glue/putty. I've googled and some say JBWeld is fine immersed in petrol and other say it'll dissolve in days.
B) Glue it (superglue or somesuch just to hold it temporarily) and heat shrink on a thin aluminium sleeve to hold and reinforce it.
C) Get it micro/laser welded back on (I've found a chap in the USA who's been repairing H*dna carbs in this way http://forums.sohc4.net/index.php?topic=118804.0 and there are firms advertising laser welding for micro welds a bit closer to home. Anyone got a recommendation?).
D) Errr..... over to you guys. Ideas please.
