float height
baz
float height
#1 PostAuthor: baz » Wed Feb 26, 2014 2:08 pm
hi all, does anybody know the measuement for the float to the carb body when setting it up on the bench, Gez 635 once told me but ive forgot it and he seems to have dissapeared off the radar......thanks
KeithZ1R
#2 PostAuthor: KeithZ1R » Wed Feb 26, 2014 2:11 pm
25mm +- 1 from memory
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Wed Feb 26, 2014 3:19 pm
Year/bike /carb size /float height in mm
1976 900 VM28SS 22
1975 Z1B 28SC 24
1974 Z1A 28SC 24
1973 Z1 28SC 24
1978 NON EMISSIONS
Z1R 28SS 26
STD 26SS 26
1977 STANDARD 26SS 25
77 LTD 26SS 25
79 LTD 28SS 26
79 STD 26SS 26
1978 SHAFT 28SS 26
1978 STDand LTD 26SS 26
Garn 1
#4 PostAuthor: Garn 1 » Thu Feb 27, 2014 12:51 am
KwackerZ1, slight error in above table... Worth a mention.
1976 900 VM26SS............ 22mm
Not VM28SS.
baz
#5 PostAuthor: baz » Thu Feb 27, 2014 8:03 am
cheers lads, think ide better print that off :wink:
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Thu Feb 27, 2014 10:13 am
Garn your right its just my typing that the problem (oh yes and needing reading glasses :oops: )
Mowjoe
#7 PostAuthor: Mowjoe » Fri Mar 21, 2014 8:07 am
For the VM26ss carbs is the 22mm with the floats pushed down against the needle jet spring cuz mine all measure 25mm ish or 20mm ish pushed down. There is a lip on the lower carb face, is the measurement from there or the gasket face?
Z900-A4 looking like a Z1B!
Garn 1
#8 PostAuthor: Garn 1 » Fri Mar 21, 2014 8:57 am
Mowjoe, the measurement should be from the surface (without gasket).
If the gasket is stuck on the surface the error will be less than 1/2 mm and that's well within tolerance.
Mowjoe
#9 PostAuthor: Mowjoe » Fri Mar 21, 2014 9:27 am
Garn 1 wrote:Mowjoe, the measurement should be from the surface (without gasket).
Thanks Garn 1!!
Mowjoe
#10 PostAuthor: Mowjoe » Fri Mar 21, 2014 9:35 am
Sorry to be a pain but I would have to bend the tangs quite a bit to acheive 22mm with it just resting on the spring pin and not pressing down. I'm at 20-21 now on all with the spring pin depressed and it was running ok apart from blocked pilot air holes on 1&2
Any ideas or should I just go for it with 22mm from the gasket surface not the Lip? Cheers mate!
Garn 1
#11 PostAuthor: Garn 1 » Fri Mar 21, 2014 2:57 pm
Shite! Mowjoe, are you sure you have Mukuni "high top" carbs (26mm)?. It sounds like you may have 28mm carbs as with the Z1, Z1a and Z1b.
If the carbs are off the engine, check the diameter of the bore closest to the engine.should be closer to 26mm than 28mm.
Ensure you have the floats the correct way up!
ensure you have small washers under needle/ jet (petrol inlet}
Pilot jets should not be Blocked!.
Shite again!
Just re-read your first post.... The floats should NOT be pushed down against the tiny spring, they should just rest held down by their on weight (gravity), when upside down for measuring!
jimmock
#12 PostAuthor: jimmock » Fri Mar 21, 2014 5:40 pm
Impressive stuff indeed Guyz, yet again!!!
Jimmock. :wnkr
I hate people I don't like !
#13 PostAuthor: PAULJAC47 » Fri Mar 21, 2014 6:01 pm
Better to use the manometer method, you can see what the levels actually are with setting with a measurement you cant tell the levels,i made mine up with some aquarium tube and a plastic screw in for the bottom of the bowl where the drain plug goes,cost pence...
Mowjoe
#14 PostAuthor: Mowjoe » Fri Mar 21, 2014 6:03 pm
Deffo VM26ss carbs! I took them off due to sooty plugs on 1&2 cyl and unable to set pilot mixture on them. I have found some sort off fibrous material blocking the pilot air holes!!! I have cleaned ,blown through with air line and fitted new carb kits so inlet needle jets are new inc washers. I have compromised and set floats at 24mm from gasket surface with floats hanging under their own weight. Re-fitted carbs and bike is running great. I will do a fuel in the tube check when I get more time but level must have been low before unless the inlet needle valves were a different make. By tne way this bike is new to me recently. :)
Compo1955
#15 PostAuthor: Compo1955 » Fri Mar 21, 2014 6:14 pm
PAULJAC47 wrote:Better to use the manometer method, you can see what the levels actually are with setting with a measurement you cant tell the levels,i made mine up with some aquarium tube and a plastic screw in for the bottom of the bowl where the drain plug goes,cost pence...
Where did you get the plastic screw thing to go into the float chamber ?
If it ain`t broke.....don`t fix it
C90
W650
ZRX1200R
Z1A
