Cam assembly
Wayne1960
Cam assembly
#1 PostAuthor: Wayne1960 » Wed Mar 19, 2014 9:58 am
I am just about to clean up the parts for the cam chain assembly. i have ordered a new cam chain so i can get the bottom half finished this week. What other parts should i definitely replace while i have the engine in bits?
Thanks in advance.
Bike now finished what a joy!
#2 PostAuthor: Pigford » Wed Mar 19, 2014 4:40 pm
All the "rubber/plastic" bits in the cam chain assembly - they go hard with time and nows the time to do it. That little guide are bolted in the barrels is also prone to breaking :?? Check all the other guide rollers to see if they're OK.
Wayne1960
#3 PostAuthor: Wayne1960 » Wed Mar 19, 2014 5:11 pm
Thanks Pigford
Wayne1960
#4 PostAuthor: Wayne1960 » Thu Mar 20, 2014 10:36 am
ok im going to have to do this a little at a time so hope you can all bear with me.
Cleaned up the idler assembly and all looks well.
The sprocket moves from side to side by 2mm.
The teeth all look in good shape.
The plastic spacers are hard but in good shape assuming the are plastic and not hardened rubber.
All the metal parts cleaned up nice.
Good to go yes / no?
