Carb rubber question
Is Vic There
#1 PostAuthor: Is Vic There » Tue Mar 04, 2014 7:29 am
When you use a bank of carbs from a GSXR where is the best place to buy the carb rubbers to fit them to the head?
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Tue Mar 04, 2014 8:44 am
Z1000j rubbers are used for bigger carbs for the z900 style heads.
Z-power sell them, or z1 enterprises.
Is Vic There
#3 PostAuthor: Is Vic There » Tue Mar 04, 2014 9:35 am
You wouldn't know the I/D of the 1000j rubbers?
I measured the O/D of the carbs, however then had visitors and drank my body weight in beer and didn't write them Dow but am sure they were 50mm!
Best I measure them again this weekend!
Is Vic There
#4 PostAuthor: Is Vic There » Wed Mar 05, 2014 5:39 am
Well, the answer is a set of GPZ1100/Z1000J/R inlet rubbers ending in -1135. These have a round lip on the inside, whereas the -1131 have a square lip, which seals badly on carbs and is intended for certain FI-models. :D
