Guys
I have just cleaned up my seat and there are 3 irritating threaded studs with nuts and washers at the front. you all have probably seen similar.
What are they for and can i cut them off!
Seat
Plate is probably the wrong description.
They are a sheet of metal about 20gauge thick and about 1/2 " wide and 4 to 6'' long. They can be made by sniping "vee's" about 3/4 "apart along the sheet and bending outwards to form a point. Once thru the leatherette they are bent back.
The strips would have to be spot welded back (if still required).
The bolts /screws can be removed.
Some seats have these vee's pressed out of the seat base around the periphery.
