Fuel tap question Z900 A4
Andrew
#1 PostAuthor: Andrew » Sat Feb 01, 2014 5:35 pm
I have just taken the sediment bowl off the bottom of the fuel tap and the rubber seal appears to have perished, can anyone tell me if this seal should be a O ring or a flat ring.
#2 PostAuthor: PAULJAC47 » Sat Feb 01, 2014 5:50 pm
Flat on the one i have but any fuel proof o ring should suffice...
#3 PostAuthor: z1bman » Sat Feb 01, 2014 5:57 pm
part no 43049-1070 available from cradley £1.86
Andrew
#4 PostAuthor: Andrew » Sat Feb 01, 2014 6:14 pm
Thanks to both of you. I will do a temporary repair so I can get out on her tomorrow (withdrawal symptoms) and order in the correct ring.
