Plans were to make sure it was roadworthy, do away with the high bars and maybe get the seat re-shaped. How bad could an mot'd bike be? Well rear tyre was worn out, as was the chain. Rear pads were down to the metal, exhaust gaskets had gone AWOL, front caliper leaks, fork bottoms off another zed had been used as handle bar clamps, swingarm was rotted out...otherwise ok
Found a nice Dresda swingarm which fitted straight on. I got a good deal on a pair of part worn rear tyres (thanks Jack) so for now am keeping the 16" wheel. The rear shocks were past it so splashed out on some Progressive ones which actually move. Also got a 530 chain kit with Talon sprocket.
Fitted some lower bars today, just need cables and a shorter top brake line.
Tank was full of gummed up fuel which was coming out in big chunks so that'll be flushed out and sealed at some point.
Also done lot's of small jobs, oil and filter, plugs, exhaust gaskets, bar clamps and bolts, made a better exhaust bracket so it hangs more naturally and not forced upwards as it was. Rear pads, larger rear indicators (yet to do front ones), fixed the seized helmet lock, air filter..
Got rid of the rear mudguard and made a bracket up for the plate/light but not sure yet, might go back to the mudguard. I'd like to fit a z1 tail unit so it might stay for now. Seat is going to be re-shaped so it is less stepped and re- covered.
I hope to get it painted as well over Winter all being well, so fingers crossed it'll be done ready for Ace Café Kawasaki day 2014.
