Anyone got a simplified wiring diagram for a J (probably any model really) with just the bare essentials to get it through an MOT and make it run.
No lights, clocks, horn, fuel gauge, ignition, IC ignitor, fuel injection, indicators, clutch or side stand switches.
Only need earths', battery, charging, on / off ignition switch, DYNA coils, tacho and possibly a brake light.
Oil pressure signal and neutral plunger signal will be plugged into existing vacant slots in tacho which are usually indicator left and possibly high beam blue i think.
I could probably figure it out eventually but the last time i tried it cost me a battery and a pair of green coils!!!
Wiring diagram j
Wiring diagram j
free manual download here with wiring diagrams
http://hotfile.com/dl/148104458/5c9f72d ... l.pdf.html
