clutch cover sight glass
KeithZ1R
#1 PostAuthor: KeithZ1R » Sun Nov 17, 2013 7:15 pm
Ive never had to replace one of these before, but it looks like in keeping with other seals you have to destroy it to get it out.
Any tips or preferred methods please guys before I start ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Hinckley
#2 PostAuthor: Hinckley » Sun Nov 17, 2013 7:26 pm
I tapped mine out using a suitable sized socket, you could re-use it if you wanted to, a new one wasn't expensive.
Installation is the reverse of removal, I applied some sealant but I don't think it was necessary - a peace of mind sort of thing.
Padders
#3 PostAuthor: Padders » Sun Nov 17, 2013 7:28 pm
On the later type covers where you cannot get a socket on it from the back. If it's in good condition nice and clear squeeze bathroom silicon sealent into it from the inside of the cover through the small slit. Once set you can knock it out clean up and re use. If cloudy just get the biggest flat screwdriver in and knock her out. Always use an appropriate sized socket to knock them back in.
Sorry if teaching you to suck eggs
PUM 13
KeithZ1R
#4 PostAuthor: KeithZ1R » Sun Nov 17, 2013 8:02 pm
thanks for the replies, I only have a slot to get at it so Ian has kinda confirmed what I thought Ta :D
Keith
:bop :gom
mistaken.
big green bus
#5 PostAuthor: big green bus » Mon Nov 18, 2013 9:33 pm
I just pushed mine out with a screw driver on the edge came out fine (but broken) :roll: only kidding. Zpower sells them if you do break it.
#6 PostAuthor: Ginger Bear » Tue Nov 19, 2013 9:16 pm
They come out real easy......... You'll be amazed. :shock:
# 104
