kawasaki gpz1100a
bigrocketrider
kawasaki gpz1100a
I am in the process of restoring a GPZ1100A1. The bike is now back together and running but I can't for the life of me figure out which way operates the choke as it appears to make no difference. Should the choke lever be level when running and up to start the bike?
its a fast idle not a choke. all the lever does is open the the throttle slightly. the engine temperature sensor + air temperature sensor control the amount of fuel it needs at all temperatures including cold starting. lever should be in up position for it to start from cold although i never used to use the fast idle as it was much easier to warm it up with the throttle until it would tick over on its own
z1bman wrote:its a fast idle not a choke. all the lever does is open the the throttle slightly. the engine temperature sensor + air temperature sensor control the amount of fuel it needs at all temperatures including cold starting. lever should be in up position for it to start from cold although i never used to use the fast idle as it was much easier to warm it up with the throttle until it would tick over on its own
Same goes for my Z1300 injection
Gavin
bigrocketrider
My first fuel injection resto - and possibly my last at this rate. Done many a carb resto but fuel injection is another ball game altogether. Pipes everywhere and very little info available on the GPZ. For the first time, I wish I had taken phots of where things went as it would have been soooooo much easier. However, got her all back together and running but I just can't seem to be able to synchro the throttle boddies.
Can you just confirm that the fast idle lever should therefore be horizontal for normal running and up to start (if needed).
Cheers guys
Cheers guys
bigrocketrider
snotie1965
bigrocketrider wrote:Thanks very much. I was clearly trying to balance the throttle bodies with the fast idle on - no wonder the revs kept increasing. Feel a bit daft now - I can strip and rebuild the bike but I don't know the difference between a choke and fast idle lever!
What was the outcome ? DFi or carbs ???
bigrocketrider
DFI. Outcome - Throttle Bodies 3 and 4 balance nicely but 1 and 2 balance but then go out of balance when revved so I can't look to equal out each side using the centre adjustment. It would appear that I have a sticking No2 throttle body and despite several attempts to free it up, I reckon a replacement set is now required. Bit of a pain really but everything else is now spot on with the bike and at least I know it runs with no nasty engine noises (apart from the miss balance that is).
bigrocketrider
