hi all
i am after some Z900 / Z1000 clock casings the internals do not need to be working as i just want the outer casing and top glass as want use for my Z project
be great if some one can help
many thanks
clock casings
You can buy new black clock lower cases from Z1 Enterprises lads.
Black tops are not avail new as far as I know.
Chrome tops + bottoms avail new from Z Power, eBay etc.
From Mark
From Mark
zpower wrote:Hi,
Yes thought about that but I wanted to use the standard clock mounts with idiot lights etc.
Hmm I suppose I could fabricate something
Phil.
Phil,
you can use standard clock munts and idiot lights with all the products I suggested mate.
http://www.z1enterprises.com/ItemDetail ... EM58-85101
Mark
clocks
this is what i want i want a complete set clocks does not mater condition as i want take original insides out and put digital instruments in there and adapt if smaller so they fit then put back together and mount etc
as i want to mount these inside and may have to make aluminum bezzel or something then fit and takes wires out bottom and put the chrome covers over so they look like original clocks from distance until you look at them face onwards if you see what i want do
