ultra sonic cleaner
DavidZ1R
ultra sonic cleaner
#1 PostAuthor: DavidZ1R » Tue Aug 27, 2013 7:02 pm
Can anyone recommend a good ultra sonic cleaner fluid for gummed up 30 year old carbs? to use in my cleaner my good lady bought home from her work :D
Rhencullen
#2 PostAuthor: Rhencullen » Tue Aug 27, 2013 9:01 pm
Try contacting Ultrawave for details of their range.
1984 GPZ900R A1
2002 ZRX1200S
1981 Suzuki GS1000G + 1977 GT750B
#3 PostAuthor: zed1015 » Tue Aug 27, 2013 11:26 pm
Use the ultrasonic as the last phase in the cleaning process.
You need to fully strip and degrease the carbs as normal prior to using the ultrasonic.
After much experimentation I found plain hot water works best with maybe a small amount of detergent (fairy liquid).
Blow them through with the airline as the final step.
#4 PostAuthor: Ginger Bear » Wed Aug 28, 2013 6:42 am
I've had some good results with this stuff;
http://mistralie.co.uk/collections/ultr ... hine-parts
But as Rob says, you'll get better results if the carbs are thoroughly degreased first.
Here's some from TLC's Z1000J that I did a couple of years back.
# 104
DavidZ1R
#5 PostAuthor: DavidZ1R » Wed Aug 28, 2013 6:36 pm
Thanks guys, the stuff GB uses is the right £ for me, the other is a bit pricey :( cheers :D got to watch the pennies on these projects :shock:
