Prior to attending Netley Marsh this year, I would like to ask if anyone knows whether the round top 1000 cam cover can be fitted to the later square top 1000 engine? Plus, can the generator and points covers be swapped as I particularly dislike the finned type that are fitted.
Anyone going to Netley this year?
Nigel
Cam Cover Swap
For the alt cover you could carefully machine off the fins to leave a recess without cutting in to the main body and then create a matching disc to fit in the recess from an early cover ( preferably a damaged one ) which has the DOHC logo on which can then be pressed /glued / welded in etc.
As for the camcover, just look at your square one and you will see a small squared off bulge either side of the larger raised bulge that clears the top camchain idler.
The early covers do not have the small bulges as the top idler is different.
Chances are you won't find an early cover anyway as they are getting rarer.
