Rear axle spacer position
kwaka
#1 PostAuthor: kwaka » Wed Aug 14, 2013 9:10 am
I'm sure i have seen this topic posted before, but for the life of me i couldn't find it. So here goes again.
Could someone tell me how and on which side the rear wheel axle spacers go. I took my wheel off quite a while ago and thought i'd remember!! :roll:
Cheers.
000zeds
#2 PostAuthor: 000zeds » Wed Aug 14, 2013 9:58 am
Wide one is brake drum side and narrow one fits in to wheel bearing oil seal on left side.
Zeds-R-Us
kwaka
#3 PostAuthor: kwaka » Wed Aug 14, 2013 11:38 am
twozeds wrote:Wide one is brake drum side and narrow one fits in to wheel bearing oil seal on left side.
So the narrow one (6mm) doesn't go under the nut?
#4 PostAuthor: ADRIAN H » Wed Aug 14, 2013 12:21 pm
What bike is it. Also I think a picture may help, of what you are trying to fit.
DogsbolloxofZ1B
#5 PostAuthor: DogsbolloxofZ1B » Wed Aug 14, 2013 6:01 pm
As twozeds says.
There are two different size spacers available to go under the nut one is 6mm thick the other is approx 4.5mm, I can't recall why though :??
kwaka
#6 PostAuthor: kwaka » Thu Aug 15, 2013 2:17 am
ADRIAN H wrote:What bike is it. Also I think a picture may help, of what you are trying to fit.
Bike is a z1b, the spacer in the middle i know goes inside the sprocket bearing seal and the one on the right goes on the brake drum side.
But where does the thin one on the left go?
[img][img]http://i243.photobucket.com/albums/ff213/Glamera1/SAM_3428.jpg[/img]
Image[/img]
Chris Riv
#7 PostAuthor: Chris Riv » Thu Aug 15, 2013 7:52 am
The one on the left looks like a washer to go under the axle nut. On my z1 the shoulder of the spindle sticks out through the chain adjuster so if i put the axle nut on without a thick washer it would run out of thread before actually clamping everything up, does that make sense?
Cheers, Chris
kwaka
#8 PostAuthor: kwaka » Thu Aug 15, 2013 8:13 am
That makes sense Chris, however i wonder why they would make a washer out of aluminium? I thought it might have gone between the seal spacer and the swingarm on the sprocket side?
KeithZ1R
#9 PostAuthor: KeithZ1R » Thu Aug 15, 2013 9:01 am
does this help
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Z1parR
#10 PostAuthor: Z1parR » Thu Aug 15, 2013 7:10 pm
Just put my rear wheel back in and as Chris Riv says that ally spacer has to go under the nut as the other two have a home .
I doubt you'd fit it in between the hub spacer and chain adjuster on the left .
6mm does sound thick though , mine is about 1.5mm .
0172 . Geoff Parr
KeithZ1R
#11 PostAuthor: KeithZ1R » Thu Aug 15, 2013 7:57 pm
think if you inspect the offending items they are all telling a story about where they go :)
Keith
:bop :gom
mistaken.
kwaka
#12 PostAuthor: kwaka » Thu Aug 15, 2013 8:00 pm
Thanks fellas, will put the thinner one under the nut, take a photo of it and post for future reference.
Cheers, Fred.
