hi all, thought i would check valve clearance on my a2, ive set them to .05 to.1 as per manual, four of them had less than .05 clearance.
Trouble is the cams are not standard, from what i can work out from other posts i have got some kenny harman cams with k/d spec grind on them, i can find a d spec grind but not k/d, so question is does anybody know what clearance i should be using, any help or info on these cams much appreciated
thanks ken
cams
