Underslung Rear Caliper conversion on a Z1R
- Fred the Zed
Hi
For reasons I won't go into, I'm thinking of converting the heavy, chunky, ugly caliper and disc arrangement on my Z1R to something a little slinkier looking and underslung. I understand that the torque arm mounting on the swingarm needs swapping to the underside from it's current position but don't worry, I can sort that easily enough.
I was looking at either a disc, caliper and carrier off a ZRX1100, ZXR750 or ZZR1100 for the mod. I want to keep the original wheel. Has anyone else out there done an underslung rear brake caliper conversion on a Z1R / Z1000 who can offer some advice please?
Fred
Fred
Paid Up Member
The Tokico caliper you are talking of was fitted to many bikes, ZX7R GSXR600/750 SRAD Early Busa's etc.
You might be able to use the complete caliper & carrier assembly, just sleeving down the spindle hole on the carrier & modding spacers to get the caliper in line with the disc.
I'm sure the disc mounting holes wont line up, so you may have to re-drill it, or make some sort of adaptor plate. or have a 'one off' disc made.
If you don't or can't use the existing carrier, it wouldn't be too hard to make a new one, from something like 10mm aluminium plate/bar.
- Fred the Zed
Thanks for the advice
Thanks for the advice guys... I'll apply my mind to what will perform / look the best.
Fred
Fred
Paid Up Member
- Fred the Zed
- big green bus
- Fred the Zed
- Fred the Zed
If you do go ahead with this conversion, you may want to think about making the caliper floating, and attaching the torque arm to the frame.
If you fasten the 'short' torque arm to the swing arm then it's straight forward enough, but as you know, when the brake is applied the rear end will dip.
In previous bikes (inc. my old Moto Martin) I turned a bush within the caliper carrier, so that when the rear wheel spindle is pinched up, the caliper and carrier bracket are free to swing 'float'. Fabricating a longer torque arm and fastening to the underside of the frame will then allow you to brake with no dipping of the rear end.
It's all down to personal preference but much prefer the feel of a floating rear brake.
Will
Will
