Fuel leak
fusionpaul
Fuel leak
#1 PostAuthor: fusionpaul » Mon Jul 08, 2013 6:24 pm
Just wondered if anyone can give me any tips on sorting out problem i'm having with fuel leaking from the carb overflow pipes ? Just recently changed the fuel tap as the old one was virtually impossible to turn on/off so got a replacement from Zpower.
Noticed the last couple of times i've taken the bike out there is a puddle of fuel under the bike ??
Cheers, Paul.
z1000puddin
#2 PostAuthor: z1000puddin » Mon Jul 08, 2013 7:09 pm
1) Float heights incorrect
2) sticky jet - This was my issue, a tiny flake, gave me an intermittent over flow from # 3 carb.
I stripped & cleaned out twice before I actually saw the little bugger.
Good luck with it
stu
Zed til Dead
fusionpaul
#3 PostAuthor: fusionpaul » Mon Jul 08, 2013 7:16 pm
z1000puddin wrote:1) Float heights incorrect
Good luck with it
stu
cheers for that, weird that mine seems to be leaking from no 3 carb as well, will have a look at w/e :)
