Not used compression gauges but you can feel a good compression with your finger
DOES THIS HELP
this started after changing valve oil seals.
compression 1=110 2=95 3=95 4=95
vacuum 1=0 2=20 3=22 4=21
zman wrote:Im no expertBut hows it possible to have compression & no vacuum.
If the valves gaps are to tight there would be no compression.If they are to big may be a bit tappy.But would still be ok to work even if not at its best.
Is there a vacuum circuit in the carb that could be block
