Z1-Bleeding brakes!!!!
wilsonsjw11
#1 PostAuthor: wilsonsjw11 » Sat May 25, 2013 1:39 pm
After many happy hours bleeding the brakes on my Z1B I am still not happy with the resistance of the brake lever,no air bubbles are now coming from the pin hole in the master cyclinder but air still comes from the rear(larger)hole is this to be normal :?:
Brakes bled through to the calipers with no air present.
Regards
Steve
jimmock
#2 PostAuthor: jimmock » Sat May 25, 2013 5:54 pm
How many times must I tell you.......
SPLIT BLEEDING.
IT IS THE ONLY WAY.
Jimmock. :wnkr
I hate people I don't like !
jimmock
#3 PostAuthor: jimmock » Sat May 25, 2013 5:57 pm
the rear(larger)hole is this normal !!!!!!!
In my experience the rear hole is always larger!!!!!
Front holes don't interest me!!
Jimmock. :wnkr
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Sat May 25, 2013 6:06 pm
Jimmock
Split bleeding has been carried out.
I won't bother responding to your other comments because it will only encourage you.
Will someone come back with a serious answer :?:
Regards
Steve
#5 PostAuthor: Pigford » Sat May 25, 2013 6:28 pm
If its a "split" 3 x line... start with furthest caliper away from m/cylinder (left) then do right caliper .
If all else fails I've taken complete system off a bike before & hung it upsidedown (calipers tied to roof) then used m/cylinder to pump thru'. Make sure any air bubbles have a direct path unwards to calipers :wink:
ALSO make sure the calipers are square to discs... if they're pissed (even slightly) the disc acts like a spring washer and you will have hell of a job bleeding them :??
DogsbolloxofZ1B
#6 PostAuthor: DogsbolloxofZ1B » Sat May 25, 2013 6:32 pm
Steve,
Tie the brake level back to the bars and leave for a few days, does help.
Mike
z1bnackerkwacker
#7 PostAuthor: z1bnackerkwacker » Sat May 25, 2013 7:39 pm
Pigford wrote:If its a "split" 3 x line... start with furthest caliper away from m/cylinder (left) then do right caliper .
Wow you progressed to 2 calipers :cl
wilsonsjw11
#8 PostAuthor: wilsonsjw11 » Sat May 25, 2013 9:10 pm
Under normal circumstances do air bubbles come out of the larger hole in the master cyclinder or should there be none at all :?:
Mike, lever has been tied back to bars for few days.
Regards
Steve
jimmock
#9 PostAuthor: jimmock » Sat May 25, 2013 9:30 pm
SERIOUSLY....
Bleed to the banjo on the out side of the MC.
Then bleed to the spliter on the bottom yolk.
Then bleed to one caliper.
Then to the second caliper.
You will get a result or your money back!!
Jimmock. :wnkr
wilsonsjw11
#10 PostAuthor: wilsonsjw11 » Sun May 26, 2013 8:06 am
Jimmock
As previously mentioned split bleeding has been carried out.
Air bubbles appear from larger hole in master cyclinder.
Regards
Steve
jimmock
#11 PostAuthor: jimmock » Sun May 26, 2013 9:35 am
Could it be possibly drawing air from banjo copper washers???
Jimmock. :wnkr
Tonka
#12 PostAuthor: Tonka » Sun May 26, 2013 5:06 pm
Are you bleeding with the master cylinder top off? If so top the fluid right up and then screw the top on tight. Pump it a few times and then take the top off again and top it up again and do the same procedure.
If this don't work your master cylinder is fecked or should i say worn. I had this issue on my Z1A and fitted a 5/8 master cylinder in the end on a single disc bike - the difference is incredible.
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
wilsonsjw11
#13 PostAuthor: wilsonsjw11 » Sun May 26, 2013 8:37 pm
Tonka
The master cyclinder has been bored out to 5/8th by a well known specialist,new piston kit fitted and pressure tested.
I will try your advised method of bleeding with master cyclinder cap on.
Regards
Steve
z1bnackerkwacker
#14 PostAuthor: z1bnackerkwacker » Mon May 27, 2013 7:12 pm
I've just fitted 2 new calipers and master on my bee and have same problem after a couple of bleeds..
Will sort it when I can be arsed :tooled
Users browsing this forum: Bing [Bot] and 25 guests
