Took it all apart today suspecting the cush rubbers at fault, they appeared fine (last owner said he replaced them with all new wheel bearings). All components of the wheel spindle present and correct. Anyone know if cush rubbers can be measured, they are pricey @?70 a set so I don't want to rush into buying new ones if the fault could lie elsewhere (although I don't know what else it could be).
Years ago I used to glue bits of old inner tube in small bike cush drives to take up slack
Also manual shows a spacer behing the sprocket for the B model, none fitted to mine- is this a problem cos there is a washer behind the front sprocket I assume to give more clearance, my concern is that having one and not the other will affect chain alignment.
