repro clocks fitting......
gordon62
#1 PostAuthor: gordon62 » Mon May 06, 2013 10:15 am
Hi all,
I knew you had to make some mods to fit these clocks, am I correct in that you have to remove some metal from the clock brackets....... :??
Charlie
#2 PostAuthor: Charlie » Mon May 06, 2013 1:38 pm
Yeah, you will ideally need a Dremel or similar to open out the original bracket. The tacho needs more work than the speedo side.
This is my post on the job from another site ;)
So, in last weeks instalment I had fitted a new tacho but it made the speedo look tatty, so a new speedo was sourced to even up the look of the clocks:
Old clock
Old binnacle:
Now, to fit these aftermarket clocks, a degree of bracket modification is necessary as the back of the new clocks are a different shape. The part that houses the odometer is slightly wider:
It means some work with a Dremel and a file to remove part of the bracket and allow the clock to seat properly ( the tacho needs more work than the speedo) but it is an easy job and just takes a few minutes with the right tools.
Then all back together and a complete new set of clocks looking all pretty :D
gordon62
#3 PostAuthor: gordon62 » Mon May 06, 2013 2:23 pm
oh cheers, excellent, I so happen to have a dremel, so will do that prob this week,
cheer.
jimmock
#4 PostAuthor: jimmock » Tue May 07, 2013 7:06 am
They new clocks look really nice.
What does it cost for them?
And where from?
Jimmock. :wnkr
I hate people I don't like !
gordon62
#5 PostAuthor: gordon62 » Tue May 07, 2013 8:35 am
I got mine from Z-Power, about 70 quid give or take.. and they are mechanical one"s, not electronic............ :D
