elr head fin
weaver
elr head fin
#1 PostAuthor: weaver » Fri Apr 19, 2013 9:56 am
i have one broken top right fin on my elr cylinder head does anyone have a damaged head they wouldnt mind liberating a fin from?
thanks
#2 PostAuthor: z1bman » Fri Apr 19, 2013 10:11 am
A GOOD ALUMINIUM WELDER /FABRICATOR SHOULD BE ABLE MAKE ONE
weaver
#3 PostAuthor: weaver » Fri Apr 19, 2013 10:59 am
ok bud,thought if I could get hold of one I could shape it to fit and then just a case of getting it welded
neilbarrett
#4 PostAuthor: neilbarrett » Fri Apr 19, 2013 2:51 pm
ive a damaged head some were ,which fin are you after
weaver
#5 PostAuthor: weaver » Fri Apr 19, 2013 3:54 pm
neilbarrett wrote:ive a damaged head some were ,which fin are you after
nice one :) ,just had a look to refresh my memory,as sitting on the bike it is the right hand side bottom cylinder head fin that is missing the whole front corner
big green bus
#6 PostAuthor: big green bus » Fri Apr 19, 2013 7:47 pm
I will have one if you do not get sorted :lol:
weaver
#7 PostAuthor: weaver » Sat Apr 20, 2013 7:41 am
big green bus wrote:I will have one if you do not get sorted :lol:
thanks,will wait to see if Neil has one :wink:
weaver
#8 PostAuthor: weaver » Wed Apr 24, 2013 4:54 pm
big green bus or neil have you got a fin you can send me? here is a pic of the offending item,I will be happy to paypal you some beer tokens in exchange :wink:
neilbarrett
#9 PostAuthor: neilbarrett » Wed Apr 24, 2013 9:33 pm
sorry forgot about it,was down me lockup tonight as well,will try and check before the weekend
weaver
#10 PostAuthor: weaver » Thu Apr 25, 2013 7:54 am
neilbarrett wrote:sorry forgot about it,was down me lockup tonight as well,will try and check before the weekend
thanks mate :wink:
#11 PostAuthor: Pigford » Thu Apr 25, 2013 8:05 am
I made a couple for my old ELR head - just got some alloy sheet (either 2 or 3mm, can't remember now?) and cut it out - filed it and got Griffs in bristol to weld it on - simples :wink:
#12 PostAuthor: z1bman » Thu Apr 25, 2013 8:22 am
Pigford wrote:I made a couple for my old ELR head - just got some alloy sheet (either 2 or 3mm, can't remember now?) and cut it out - filed it and got Griffs in bristol to weld it on - simples :wink:
agreed it does not have to be a Finn from another head if your welder knows what he is doing he will have the material to do the job. the guy i use has been known to build it up with weld if there's not that much of the aluminium missing
