Wheel Bearings
Wheel Bearings
Hi, Could someone advise the best method for removal of front and rear wheel bearings please .
these are a brilliant bit of kit better than using a drift as this fits dirrectly into the bearing + you just knock in the tapered tool from the opposite side
http://www.justoffbase.co.uk/Motorcycle ... tAodqmAAAA
Thanks for your help guys. I guessed I would be drifting them out but there doesnt seem to be a lip/point to get any purchase on. Not tried yet though thought best to seek the knowledge on here first.
That tool may be on the agenda if I dont get any joy drifting !
Thanks for the circlip shout too.Its actually an a4 but I have learned something else. Cheers everyone g
Or take a grinder to your existing drift to get a nice 90 degree face on it so it grips better onto the inner side of what you're drifting
Sometimes the tubular spacer between the 2 wheelbearings is very snug and it's difficult to find an "edge" to drift against (so your blind bearing puller won't work either). in that case I lower the drift down till the tip is alongside where the end of the spacer is , and hit the drift sideways, this knocks the spacer sideways a bit and hey presto an edge of the bearing is revealed to drift against.
the spacer can be a pest but don't be tempted to leave it out!
gray
