Clutch inner plastic part
Hobbo
#1 PostAuthor: Hobbo » Mon Mar 04, 2013 10:53 pm
Guyzz
As title says i am after the plastic part of the clutch mechanism that bolts inside the clutch housing and has the threaded adjuster screwed into it .
Hope you know what i mean
phil
#2 PostAuthor: z1bman » Mon Mar 04, 2013 11:12 pm
part no 13118-007
Keefleaf
#3 PostAuthor: Keefleaf » Tue Mar 05, 2013 1:07 am
Think it's called a worm gear.
#4 PostAuthor: z1bman » Tue Mar 05, 2013 5:38 am
KeithZ1R
#5 PostAuthor: KeithZ1R » Tue Mar 05, 2013 1:14 pm
probably got one if i can figure out what you want ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
andy c
clutch worm gear
#6 PostAuthor: andy c » Tue Mar 05, 2013 7:59 pm
If you get stuck ive got one
Andy
Z1parR
#7 PostAuthor: Z1parR » Tue Mar 05, 2013 8:20 pm
http://www.cmsnl.com/kawasaki-1978-kz10 ... ml#results
Item no. 19
I hope i've identified the right bit Phil ?
0172 . Geoff Parr
