Z1000 REAR DISC
z1000puddin
Z1000 REAR DISC
#1 PostAuthor: z1000puddin » Sun Feb 24, 2013 9:33 pm
Gents,
Can anyone advise if the rear disc from a 1978 16" ltd mag wheel will fit a 1978 A2 18" rear spoked wheel ?
ie are they the same offset ?
Zed til Dead
#2 PostAuthor: z1bman » Sun Feb 24, 2013 10:16 pm
ltd has a smaller disc + is the same as z650C / csr. calliper + mounting bracket are also different dimensions
z1000puddin
#3 PostAuthor: z1000puddin » Sun Feb 24, 2013 11:10 pm
Thanks Z1bman.
Need to look somewhere else.
Stu
Zed til Dead
nigel bessant
#4 PostAuthor: nigel bessant » Mon Feb 25, 2013 8:19 pm
Does it not depend on the ltd model? Mine had a 16"rear wheel but had an A1 swing arm and the same caliper as fitted to an A1. Was basically an A1 with silly wheels, a fugly seat and peanut tank.
I have the disc off of it if you need measurements.
Nigel
z1000puddin
#5 PostAuthor: z1000puddin » Mon Feb 25, 2013 8:34 pm
Nigel,
I have just measured both my A1 rear discs and the dimensions are
Dia -290mm
Offset (Face of disc to face of mount face) -23mm
The Ltd disc I have has
Dia. - 277mm
Offset - 19mm
If you can meausre your one that would great.
Stu
Zed til Dead
steve bowdler
#6 PostAuthor: steve bowdler » Mon Feb 25, 2013 8:45 pm
Interesting I haveB1 with A1 wheel but small ltd caliper have to check size of my disc :??
nigel bessant
#7 PostAuthor: nigel bessant » Mon Feb 25, 2013 8:59 pm
Stu, I reckon z1bman has it spot on with his info (well done sir).
The disc I have has the same dimensions as your ltd one. Weirdly though, the caliper was identical to an A1. It must look similar but is clearly not.
Nigel
z1000puddin
#8 PostAuthor: z1000puddin » Mon Feb 25, 2013 9:24 pm
Nigel,
Yes the rear caliper is a lot different , I have one on the shelf pic below.
I better keep on looking for a rear A1, A2 disc or Z1R I think are the same.
Zed til Dead
nigel bessant
#9 PostAuthor: nigel bessant » Mon Feb 25, 2013 9:44 pm
Stu, that is nothing like the caliper I had on my ltd. mine looked like a Z1R caliper.
z1000puddin
#10 PostAuthor: z1000puddin » Mon Feb 25, 2013 9:57 pm
Its the z1r calliper that I have on my thou.
Zed til Dead
nigel bessant
#11 PostAuthor: nigel bessant » Mon Feb 25, 2013 10:15 pm
Yep, that's the one. I don't know if it worked with the smaller diameter disc as I never rode the bike. :lol:
#12 PostAuthor: z1bman » Mon Feb 25, 2013 10:34 pm
z1000puddin wrote:Nigel,
1977/1978 z1000 B1/B2 ltd uses the above calliper. 1979/1980 z1000 B3/B4 uses the z1r type calliper
