My bike has Renthal bars and H***a switchgear. The switches have a small protruding plastic pin on the inner surface that is designed to locate into a hole in the bars. If you grind off the locating pin, then the switchgear won't clamp the bars properly and it rotates round when pushed (don't ask how I discovered this...).
The Renthal instructions carry a big warning about not drilling the bars but I would have thought that a small (~3mm) hole towards the end of the bar would OK.
Any member got any experience/ thoughts on this? Thanks!
Is it safe to drill Renthal bars?
- Mark Tiller
jphaynes669
Users browsing this forum: Bing [Bot] and 84 guests
