So I have managed to strip my rotor off the bike to reveal the starter clutch rollers I have a number of questions so please go easy
1 I was able to remove the rollers etc without splitting the rotor and starter clutch is this normal.
2 There dose not seem to be any visable flats on the rollers only some disscoloration on one roller is this normal.
3 All the springs seem to be equal length.
would the clutch give ramdome problems with the above. I intend to replace the parts "just in case".
Starter clutch parts
						it is normally the starter gear that causes the problem. check the surface where the rollers grip the gear ( machined surface should be perfectly round )turn the gear with your hand + grip the machined surface with you fingers if you can feel any unevenness in the surface it is scrap. also the rotor surface wears + causes the rollers to stick. just clean the rotor surface with some wet & dry until you have a smooth surface
