Oil cooler size
- harrythemagnum
Oil cooler size
Going to fit an oil cooler, what is the better size, 10 or 13 row?
What a wonderful philosophy you have,
- harrythemagnum
harrythemagnum wrote:Total stock motor.
I keep looking at the Jap bling bikes and most have thirteen row, but would I need an uprated pump with one?
Oil pump will be OK - they chuck out big volumes, rather than pressure
The GPz11 only has a couple of rows... and that crates a fair bit more BHP (heat)
oil cooler
If you are using the cable drive for the tacho this limits the room you have. If you are using electronic tacho and the head has had the cable drive blanked off more room. I used cable drive on mine ( see photo in last post) This limited me a lot on size of cooler. Hope this helps you.
- harrythemagnum
