what is the best electronic ignition ?
- chrispyduck
The points on my Z1a have come to the end of their useful life and i wish to change to electronic ignition. Not being the most confident mechanic what would be the best and most convenient system to fit and what tools would i need.
Fat girls are like M****s, they are fun to ride, you just don`t want your mates to see you.
DYNA 'S'.
Easy fit, plugs in on same connections as the points.
No ignitor box or anything else to complicate things.
Very reliable.
Got these on all my zeds.
Very reliable.
- Mark Tiller
Dyna s...... fitting guide here http://z1ownersclub.co.uk/forum/viewtop ... light=dyna
- chrispyduck
yes you will need a strobe light to set the ignition
dyna s here £10 cheaper than z power
http://www.ebay.co.uk/itm/Kawasaki-Z1B- ... 4609d0045b
You don't need a strobe light to set a Dyna.
Static is fine with a degree wheel - just hold trigger at "Full Advance" with pistons at around 35 degs BTDC and check sparks fly
This may well be cheaper.... http://www.z1enterprises.com/ItemDetail ... em=DYDS2-1
Pigford wrote:You don't need a strobe light to set a Dyna.
if you don't have a degree wheel a strobe light will do
z1bman wrote:Pigford wrote:You don't need a strobe light to set a Dyna.
if you don't have a degree wheel a strobe light will do![]()
OK - a stobe light is easier
It will be....... Trust me.
- chrispyduck
Thanks for all the advice......have ordered Dyna S from Z1 Enterprises. £40 cheaper than Z Power even with postage
Reckon this is due to Dyna S being an American product.
One question regarding setting it up they are recommending static timing......any advice on this
