Flaming Zed thou !!
z1000puddin
Flaming Zed thou !!
#1 PostAuthor: z1000puddin » Sun Jan 06, 2013 10:43 pm
Guyz,
I took off my V&H sidewinder exhaust from my black zed today(sold to a club member)
Whilst I had the pipes off I started the bike up as it hadnt been started for a few weeks ( dont know why- just wanted to :lol: )
When I looked into the exhaust ports, I noticed that there were quite a bit of fire coming out around the valves Is this normal ??
#1 & #4 were really "orange" around the valve & shooting flames out about 2", but #2 & 3 did not look to bad & no flames shooting out. I was going to take a video, but I didnt fancy getting my face burnt off !!
I am thinking it may be down to valve timing, but without adjustable sprockets
how can this be adjusted ?
Or could it be down to valve clearances.
The bike has standard cams fitted & wiesco pistons
Any pointers ??
Stu
Zed til Dead
garyd
#2 PostAuthor: garyd » Sun Jan 06, 2013 11:18 pm
I did the same thing...only in 1978...got blue flames out of all four...so something doesn't sound right.
scott
Junior Section leader
#3 PostAuthor: scott » Mon Jan 07, 2013 8:01 am
I',ve seen an engine run with no pipes and that produced flames.....the bike was in perfect condition engine wise.
#4 PostAuthor: zed1015 » Mon Jan 07, 2013 9:51 am
Flames are normal, obviously!
Can't be cam timing as it is the same on all cylinder regardless of having it adjustable or not.
Different flame colour is down to air/fuel ratio content.
Likely suspects are the carb settings being slightly off, carb manifold air leaks etc.
Probably worth setting up with a COLOURTUNE if you want matching flames.
#5 PostAuthor: Pigford » Mon Jan 07, 2013 10:08 am
zed1015 wrote:Probably worth setting up with a COLOURTUNE if you want matching flames.
That made me giggle :lol:
z1000puddin
#6 PostAuthor: z1000puddin » Mon Jan 07, 2013 10:22 am
I like the idea of "Matching Flames"
I was more concerned about the "ring" of fire I was seeing around the valve seat.
Stu
Zed til Dead
#7 PostAuthor: zed1015 » Mon Jan 07, 2013 10:45 am
The ring of fire is normal but staring at your seat and observing it is not a healthy pastime and should not be done in public.
I suggest applying your excess energies to a wholesome hobby like jogging or rock climbing should increase your chances of blending in to normal society.
If you insist on persuing this activity may i suggest the mirror on a stick method similar to what the dentist uses to avoid future eye and back problems in later life.
KeithZ1R
#8 PostAuthor: KeithZ1R » Mon Jan 07, 2013 4:30 pm
Far and away the funniest thread Ive come across on this forum for some time :hys
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
z1000puddin
#9 PostAuthor: z1000puddin » Mon Jan 07, 2013 7:17 pm
zed1015 wrote:The ring of fire is normal but staring at your seat and observing it is not a healthy pastime and should not be done in public.
:stak :stak :stak
Come on Jimmock where are you :?: Surely you must have a thought on this
Zed til Dead
#10 PostAuthor: paul doran » Mon Jan 07, 2013 9:33 pm
:stak :stak :stak
dont encourage the sad git
london calling
#11 PostAuthor: london calling » Tue Jan 08, 2013 7:27 am
Rob,you get my vote for being the Z1 Celebrity Doctor/Agony Aunt.
Daytime TV is waiting for you :lol: :lol: :wink:
Not sure if you'll be able do much for "KOSHER" Piglet and his ironing fettish :?? Maybe a spit roast and some apple sauce :?:
Jack
