Do you know an engineer who can fix this cylinder?
malmojoe
#1 PostAuthor: malmojoe » Tue Dec 04, 2012 8:27 pm
was cleaning up the engine on a H1 I've bought and saw this..... :eek
There's a crack all the way down the transfer port going right through to the liner. Can this be sorted out??
I've not got any experience with getting this kind of thing sorted so would appreciate any leads.
thanks
nigel bessant
#2 PostAuthor: nigel bessant » Tue Dec 04, 2012 8:38 pm
You could try Larry Houghton at Lamb Engineering. He is based in South Newton in the industrial estate behind the car sales on the main road through south Newton. Watch out for the speed camera. While you are there check out the bikes he has built. He is one clever bloke and a nice one too. His bikes have won shows here, Europe and America.
#3 PostAuthor: z1bman » Tue Dec 04, 2012 8:47 pm
quite a common thing on the h1. you can either look for another cylinder probably the cheapest option or get yours re sleeved
http://www.pjme.co.uk/acatalog/Cylinder ... eving.html
malmojoe
#4 PostAuthor: malmojoe » Tue Dec 04, 2012 8:54 pm
cheers guys, Nigel, I have been meaning to go and see Larry. I've heard good things about his work too.
z1bman, I;m not sure how much I could get another for and how long it would take so would rather get it fixed if it's not stupid money. Thanks for the link.
What about just welding it and then re-boring?
#5 PostAuthor: z1bman » Tue Dec 04, 2012 9:15 pm
have you tried rick brett
malmojoe
#6 PostAuthor: malmojoe » Tue Dec 04, 2012 9:21 pm
not yet but that's an idea. Ill put a wanted note on his site too.
#7 PostAuthor: ZedHead » Tue Dec 04, 2012 10:07 pm
If the liner is anything like the are on zeds they are not too hard to change
#8 PostAuthor: z1bman » Tue Dec 04, 2012 10:26 pm
they are not like a four stroke motor the the aluminium cylinder is cast around the metal cylinder sleeve making it impossible to remove by the same method of removing a four stroke sleeve., they have to be machined out + then the new sleeve is fitted in the same way as a four stroke probably cost £150 +
IanM63
#9 PostAuthor: IanM63 » Wed Dec 05, 2012 9:45 am
Try Motrac. They did a great job welding and re-plating my KX500 cylinder.
http://www.motrac-racing.com/
#10 PostAuthor: PAULJAC47 » Wed Dec 05, 2012 1:06 pm
Try giving Malc Anderson a Pm on here he may give you a lead...
