Remove Rotor
Remove Rotor
Would anybody be able to tell me the size (Diameter and Pitch) of the bolt I require to remove the rotor on my Z1B as I have to investigate a noisey starter clutch.
  Also has anybody heard of placing a ball bearing on to the end of the crank ahead of the bolt in order to ease breaking the taper
 . Just to prove that I am stupid
  is it a right or left hand thread.
						- z1000puddin
