what are the part no's for the bolts holding the lower engine mounting plate to the frame and also the two mounting brackets for the battery box/rear brake switch, looked at various parts diagrams but cannot be certain. dimensions would be ok if no part no's.
cheers wayne
bolt part no's
Lower bolts 2 x M8 X 18 Part no. 110B0818
Not quite sure which other mounting brackets you mean or which model, but if it's the rear engine mounts the numbers are :-
Z1/Z1A = L/H 32030-027
R/H 32030-028
Z1B = L/H 32030-046
R/H 32030-045
A4 = L/H 32030-055
R/H 32030-056
A1/A2 = L/H 32030-066
R/H 32030-067
R/H 32030-028
Z1B = L/H 32030-046
R/H 32030-045
A4 = L/H 32030-055
R/H 32030-056
R/H 32030-067
https://www.kawasakiepc.com/SystemSearc ... N=38256406
part no's i need are in section 15 for the bolts to the frame for 43,44 and 47. these are for a z900 a4
Re: bolt part no's
wayno wrote:what are the part no's for the bolts holding the lower engine mounting plate to the frame and also the two mounting brackets for the battery box/rear brake switch, looked at various parts diagrams but cannot be certain. dimensions would be ok if no part no's.
cheers wayne
Which bike and year is this for.
Re: bolt part no's
ADRIAN H wrote:wayno wrote:what are the part no's for the bolts holding the lower engine mounting plate to the frame and also the two mounting brackets for the battery box/rear brake switch, looked at various parts diagrams but cannot be certain. dimensions would be ok if no part no's.
cheers wayne
z900a4 1976
In the downloads section of this site there is a parts list for z900 a4, along with other useful stuff.
http://www.classickawasaki.se/
