no oil light
floydsz1
no oil light
#1 PostAuthor: floydsz1 » Sun Oct 28, 2012 5:30 pm
Just bought a z1b. the oil light doesnt come on. (bulb is ok) engine runs fine though. I get 12 volts to the wire that goes to the switch. does the switch earth the wire when the engine is not running so making the bulb come on.
I have removed the switch. it does'nt seem to make any difference if i do a continuity test on the switch, ie with the plunger pushed in.
if the switch is faulty has anyone got one i can buy,
cheers,
peter
Z1b, z900 A4, zxr750 m2, zrx1200
Z1000 (2003) lawson thingy,
Z1000 (2004) z1b lookalike ,
Z1000j lawson race bike,
Gsxr750H.
Mark Tiller
#2 PostAuthor: Mark Tiller » Sun Oct 28, 2012 5:34 pm
#3 PostAuthor: Pigford » Sun Oct 28, 2012 5:34 pm
Switch works by earthing out :wink:
floydsz1
#4 PostAuthor: floydsz1 » Sun Oct 28, 2012 5:36 pm
Yep thought it did, if i earth the wire the light comes on, looks like the switch is buggered. :cry:
typical. i did have one a while ago but gave it to someone
Gsxr750H.
#5 PostAuthor: z1bman » Sun Oct 28, 2012 6:16 pm
the brass circular plate which is attached to the switch should touch the crank case when fully screwed in. i have fitted a small washer under the plate on previous occasions so it makes contact to earth when switch is fitted .
floydsz1
#6 PostAuthor: floydsz1 » Sun Oct 28, 2012 8:02 pm
not had a proper look at the switch yet, hopefully i can get it to work as it looks quite new.
Gsxr750H.
Padders
#7 PostAuthor: Padders » Sun Oct 28, 2012 8:17 pm
I have a spare from a Z1000A2 if its any good to you let me know and your details and I will get it in the post.
PUM 13
floydsz1
#8 PostAuthor: floydsz1 » Sun Oct 28, 2012 8:22 pm
Thanks padders, was thinking the plunger on mine might not be going down far enough and earthing, Ill have a look in next couple of days, if i cant get it sorted ill have yours please, I'll let you know how i get on.
cheers,
peter
Gsxr750H.
Padders
#9 PostAuthor: Padders » Sun Oct 28, 2012 8:29 pm
No problem Peter
PUM 13
jimmock
#10 PostAuthor: jimmock » Sun Oct 28, 2012 9:11 pm
Works just like a courtesey light switch on a car door pillar.
Does anyone know at what pressure the light comes on at??
I'd imagine about 6psi??
Jimmock. :wnkr
I hate people I don't like !
floydsz1
#11 PostAuthor: floydsz1 » Tue Oct 30, 2012 5:26 pm
Thanks mr Padders, I wont need your switch.
I have done what Z1Bman said and fitted a small washer under the brass washer and all is ok.
Many thanks again.
Gsxr750H.
#12 PostAuthor: Pigford » Tue Oct 30, 2012 6:04 pm
jimmock wrote:Works just like a courtesey light switch on a car door pillar.
Light comes on when pressure drops too low - some less than 2psi..... But it also depends on oil type/viscosity too :!:
jimmock
#13 PostAuthor: jimmock » Tue Oct 30, 2012 9:38 pm
2psi??
I think the engine would be wrecked BEFORE the light comes on!!
Jimmock. :wnkr
wilsonsjw11
#14 PostAuthor: wilsonsjw11 » Wed Oct 31, 2012 6:16 am
The engine runs at a very low oil pressure.
Regards
Steve
PJ
#15 PostAuthor: PJ » Wed Oct 31, 2012 6:50 am
Padders wrote:I have a spare from a Z1000A2 if its any good to you let me know and your details and I will get it in the post.
Hi Padders I need one, how much do you want with postage ??
PJ
