Now this is a maybe but putting this on just incase someone has one
18 inch
z650 rear drum wheel
Just looked in the garage , I've a rear drum /spoked wheel that i think's off a 650. got it in a job lot with a z650B3 project which is now gone
18" diam, 2.15x18 rimsize stamped on the rim
17mm diam axle
"usable range" casting on the brake backplate
42 teeth on the sprocket. 6 bolt sprocket carrier.
drum diam looks like 178mm.
will need respoked (rusty) and new rim ( hefty tyre lever marks or something) and blasted/polished.
complete with axle, nut and spacers,
and chain adjusters possibly if i can find them
17mm diam axle
gray
17mm diam axle
17mm diam axle
gray
