Does a pair or 1.5 ohm (Brown / Red) Dyna coils sum to 3 ohms when wired in series?
Or is resistance not an addition process but an iterative one?
This is for a four coil setup on a bike with an 8 plug head running Dyna 'S'.
I believe the correct resistance should be 3 ohms for Dyna 'S' but with four coils (1.5 ohms each) i need to check the value of 2 times 1.5 in series.
Reason for asking is i have seen it done with four Grey Dyna coils of value 2.2 ohms.
Ohms addition / subtraction
- london calling
connect em up and measure it
although from my dim and distant classroom days coils are measured in inductance so it may not be that simple although as Jack has pointed out series is summing parallel is reciprocal summing
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
london calling wrote:Resistance in series is added together,eg 2=2+4
In parallel it's the reciprocal of the reistances combined,then reciprocatedagain.
This means the overall resistance is always less than the smallest resistance.
Correct
Resisters in series R = R1 + R2 +R3 etc
Resisters in parallel = 1/R = 1/R1 + 1/R2 + 1/R3 etc
