Hi
took my bike out at the weekend,first time in a few weeks and it was running really bad like on 3 cylinders, I checked the spark at the plugs and just seem to be getting an intermittent or no spark, does this mean its the coils? I will take the tank off at the weekend and check the connections etc. It has electronic ignition on it, if I renew the coils would it be a good idea to buy Dyna S ?
any advice appreciated
Bob
ignition coils?
Dyna S are the way to go for reliability. but check everything else first. Voltage to coils resistance across coils. there are a couple of good threads in here all bout coils. read up first and do some basic checks before you invest.
good luck.
good luck.
Andy
change the plugs first a duff coil would show on one pair of plugs where as a plug with high resitance or an internal short through the insulator will spark intermittant just a thought
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
I guess you need a multimeter , you should set it to resistance/ ohms,
then attach the probes to the low tension ( thin ) wires- any way round - should get low resistance
then put the probes into the 2 plug caps at the end of the HT leads- once again low resistance.
There should be infinite resistance between any thin wire and any HTlead/ plug cap
(i think)
(i think)
gray
thanks for the replies
I went to the bike at the weekendand it started and is running perfectly. I think the problem could have been the key in the ignition switch...since I have had the bike (14 years)whenever I have started it I take the key out or it falls out as I think in its colorful history the switch has been forced probably an attempt at theft. once or twice in the past the bike has cut out while I have been riding it but when I`ve put the key back in and wiggled it the ignition light has come back on, anyway I have ordered a new one and will see what happens, so possibly this could solve it I will let you know
Bob
Bob
