ANY IDEA WHAT THIS IS
Padders
#1 PostAuthor: Padders » Mon Sep 17, 2012 8:15 am
I am splitting a MK11 and this was fitted across the two coil mounts not sure what it is any ideas.
z650freak
Head
#2 PostAuthor: z650freak » Mon Sep 17, 2012 8:47 am
Hi Ian. Any fin damage on head and barrels? Cheers. Paul (first dibs if possible!)
#3 PostAuthor: z1bman » Mon Sep 17, 2012 9:01 am
its a ballast resister for the headlight
Taffus
#4 PostAuthor: Taffus » Mon Sep 17, 2012 9:01 am
Ballsst resistor for the ignition system
http://autorepair.about.com/cs/generali ... 52502a.htm
ok just saw the other post and as he is a kawasaki mechanic ...he right! :D
(\__/)
(")_(")Image
Padders
#5 PostAuthor: Padders » Mon Sep 17, 2012 9:09 am
Thanks for the info guys never seen one before so a bit difficult to put on e bay when you have no clue what it is!!!
#6 PostAuthor: z1bman » Mon Sep 17, 2012 9:31 am
my mistake it is a ballast resister for the ignition sorry :( :( :( :(
Padders
#7 PostAuthor: Padders » Mon Sep 17, 2012 9:39 am
No need to appologise thanks for taking the time to reply.
750steve
#8 PostAuthor: 750steve » Mon Sep 17, 2012 10:37 am
Hmmmmm.....just to throw some more confusion on this im pretty certain it's for the headlight, Euro models came with them to dim the headlight but US spec bikes didn't have them.
But it's deffo a ballast resistor
Taffus wrote:http://autorepair.about.com/cs/generalinfo/a/aa052502a.htm
& yes i did read that
Padders
#9 PostAuthor: Padders » Mon Sep 17, 2012 11:06 am
After some further checking it turns out to be a ballast resister required for the ignition part number 28018-1018.
Never seen one before but you live and learn.
Cheers guys
750steve
#10 PostAuthor: 750steve » Mon Sep 17, 2012 12:22 pm
Ah well im fookin wrong again! The wife must be right
