Z1000A2 with 180 tyre - advice please
Holeshot
#1 PostAuthor: Holeshot » Wed Sep 05, 2012 11:07 am
I’m revising the rear end on my A2 and would appreciate any advice I can get from the huge collective knowledge here ;)
Basically I want to run a 180 tyre on a spoked rim using the standard hub. I’m using a deepbrace JMC swingarm.
I’m guessing I’ll be using a 5.00 rim and a 5/8â€￾ offset front sprocket with a 530 chain.
The bit I’m unsure of is the offset when getting the wheel rebuilt.
Anyone done this before??
Be great to hear any experiences.
Cheers :)
#2 PostAuthor: Pigford » Wed Sep 05, 2012 11:20 am
You'll need to check wheel alignment yourself and put it all together and see where the centre of the rim is in relation to the hub. This way it'll be quite easy to sort the axel/spacer bits out & get the wheel to suit.
As a guide, my Z1000 runs a JMC slotted drag s/arm, 5/8" & 630 with a Gixxer mag + 180 tyre..... so you could check a Gixxer/Bandit wheel out for off-set?
I think the best bet (as JMC arms vary in construction) is to rig it all up & do some careful measuring :wink:
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Wed Sep 05, 2012 11:23 am
Some good info on this in a very old thread when I asked the question!
http://www.z1ownersclub.co.uk/forum/vie ... ght=wheels
LondonZ1
#4 PostAuthor: LondonZ1 » Thu Sep 06, 2012 11:50 am
I think you will find that a 5.5" rim is the recommended width for a 180 tyre. I am in the process of fitting a 180/55 tyre on a 17"/5.5" wheel at the rear but using cast wheels. The bike will sit lower at the rear unless you fit longer shocks as the diameter of the tyre is smaller than standard.
If you do fit longer shocks, beware chain tension as the chain may be too slack when the shocks are extended. Sanctuary sell a chain tensioner that bolts to the LH centre stand bracket to keep tension more stable as the shock extends. Link below.
http://www.noblest.co.jp/products/detail105.html
Not sure for an A2, but on a Z1/900 you also need to modify the LH footrest mountings studs. These studs screw into the frame and have a locknut on the inside. The 5/8 offset sprocket means that the chain will foul the locknut and you need to shorten the stud, ditch the locknut and use loctite instead.
LondonZ1
#5 PostAuthor: LondonZ1 » Thu Sep 06, 2012 11:55 am
..and check that your 180 tyre is happy with an inner tube. Most 180 tyres are designed for tubeless applications.
#6 PostAuthor: zed1015 » Thu Sep 06, 2012 12:41 pm
You need a 5.5 in rim for 170/180 tyre and have the wheel rebuilt with the same offsets as std so that the rim/tyre runs central as std (do not offset the rim to gain chain clearance)
Use a front sprocket with 5/8th offset (this is the widest with std frame)
To account for the smaller rolling radius of the 17" rim set the gearing at 1.94 -1 (if going for std gearing) as this gives the nearest equivalent distance travelled per tooth as the original 2.2 -1.
As above the footrest bolts will need shortening and the nuts looseing to avoid fouling.
630 chain will "just" clear the frame and 180 tyre by a gnats and 530 will give around 5mm clearance.
If you drop a straight edge from the offset front sprockets inner face on to the swingarm spindle you will find that this distance is 101mm from the spindle center or 218.5mm from the right hand inner frame stub.(this is based on the average 235mm inner frame width and can vary by half a mill or so either way) so to align the rear sprocket the carriers mounting face must be 101mm (+/- half a mill depending) from the hubs center and either some machining or a spacer will be required depending on the hub/carrier being used.
njwmct
#7 PostAuthor: njwmct » Thu Sep 06, 2012 3:05 pm
Just a little more info.
As per info from another member - 180/55-17 tyres are designed to fit a 5.50 inch rim.
As far as an inner tube goes Continental do one to suit which they call a 'G17'
garyd
#8 PostAuthor: garyd » Thu Sep 06, 2012 6:27 pm
Mr Holeshot,
I bought a spare 5/8th offset 530 sprocket when we did a group buy. I doubt I'll have a need for it for many a year and happy to pass it on for what I paid.
£33 plus £3 postage if my memory functions...
19 tooth, 530, 5/8 off-set, Z13 splines to fit models up to and including KZ1000 D3 and G1.
Here's a link to the thread.
http://www.z1ownersclub.co.uk/forum/vie ... sc&start=0
Gary
HowieD
#9 PostAuthor: HowieD » Thu Sep 06, 2012 6:37 pm
LondonZ1 wrote:Sanctuary sell a chain tensioner that bolts to the LH centre stand bracket to keep tension more stable as the shock extends. Link below.
Does anyone know where I can get one of these or something similar in the UK or EU ??
regards
Howie
CD185, Maggot, Z1-R, Horace
#10 PostAuthor: ADRIAN H » Thu Sep 06, 2012 7:07 pm
regards
Howie
I would phone Ray Debben, Debben performance, Ringwood.
Taffus
#11 PostAuthor: Taffus » Thu Sep 06, 2012 7:28 pm
look in Ginger bears project.....he made one! :D
(\__/)
(")_(")Image
#12 PostAuthor: Ginger Bear » Mon Sep 10, 2012 3:51 pm
Here is the one I made earlier.......
# 104
#13 PostAuthor: ADRIAN H » Mon Sep 10, 2012 4:27 pm
Ginger Bear wrote:Image
Do you know the dimensions for this chain adjuster ?
#14 PostAuthor: Ginger Bear » Mon Sep 10, 2012 5:46 pm
Sorry Adrian, no dimensions. I used a cardboard template to ensure everything worked out. Needed to make the angle fairly acute so the thing didn't foul on the frame cross member.
Wheel is a 'turned down' skateboard wheel.
Bike has now gone to a new home, so I can't even go out & measure it for you. :|
# 104
#15 PostAuthor: ADRIAN H » Mon Sep 10, 2012 6:04 pm
Ginger Bear wrote:Sorry Adrian, no dimensions. I used a cardboard template to ensure everything worked out. Needed to make the angle fairly acute so the thing didn't foul on the frame cross member.
Thanks for letting us know. GB
Users browsing this forum: No registered users and 85 guests
