Can anybody give me the hight to the top of float using the upside down method, measuring from the gasket face of the carb body, in mm's please.
Thanks.
Z1b float hight? using the upside down method
- DogsbolloxofZ1B
- Bruce Sexton
- Bruce Sexton
jimmock wrote:Bruce Sexton wrote:I set my Z1a up at 21mm using the upside down method. not had any problems to date.
Bruce
Bruce,
Do you take the mirrors off first??
No you don't need to take them off, just angle them away so you dont end up looking up your own arse
and careful you dont scratch your paintwork.
Bruce
Why were Z1A's not Blue???????
Clymer (end of Chap7) has a list of settings from '73 Z1 thru to '79 Z1000,
They recommend ..all Z1, Z1A & Z1B have float levels set at 24 mm +- lmm.
That's 3.5 mm down from the bottom-most flange of the carb top!
Must admit, I often have needle & seat leaking troubles, even after replacing them.
I always think there is more pressure on the needle to seat, if the levels are set, such that the float will trying to force them together! Am I correct?
