Z1 indicator panel wiring
malmojoe
Does anybody know which lamp goes where? Just looked at the wiring diagram in the manual and there's no colours on it. Very useful.
malmojoe
Thanks Chris, but I didn't have my switches on at the time. All done now and I did it that way.
Adrian, thanks a lot for that I had some problems and had to try and follow the lines in the manuals diagram, which is not easy. If I had had this it would have been much quicker. I'll print it off.
BTW, my headlight wouldn't work and the fault was actually within the horizontal switch on the right control. I took the switch to pieces and cleaned the contacts with wet and dry and that sorted it. Just incase anyone else has that problem.
