Just a quick question i notice sometimes there is oil/fuel dripping out of the drain plug on what i think is the surge tank???(left hand side) is that anything to worry about?
garyd wrote:That box (Airbox) has a tube from the crankcases that allow vaporised oil to feed up into the airbox and get burnt up by the engine. But some of it condenses in the airbox and drains out...so if you have a lot, then the crankcases are develoiong too much pressure and pushing more oil vapour up into the box.
A symptom of leaking piston rings allowing some of the exhaust to slip by and go into the crank cases.
