Is this right ?
t0ne
Is this right ?
#1 PostAuthor: t0ne » Fri Jul 20, 2012 5:30 pm
I'm a complete novice at this and I'm trying to work out exactly what I've bought - the numbers make it a KZ1000 B1 LTD, I was told it's had a few tweaks over the years such as the K&N filters, Stage 3 Dynajet and Dynacoils.
The fuel tap, apart from being unbelievably stiff, fouls the top of the carb, is that ever right ?
The tap has two fuel lines by the look of it one going between the first two carbs and the second between 3 and 4. Could it be a non-standard tap or non-standard carbs or are they all like this ?
Any pointers gratefully received :)
Padders
#2 PostAuthor: Padders » Fri Jul 20, 2012 5:35 pm
Its a tight fit normally but as your bike has the filters fitted you will probably find your carbs have just drop down a little and now the gap is too tight between the carb top and tap. As for the tap being stiff you can buy a recondition kit which should sort out the problem. Try Z Power or Z Supplies.
#3 PostAuthor: ADRIAN H » Fri Jul 20, 2012 5:36 pm
Looks like you have got a fuel tap from a different kwak on there. As I thought all z1 - z1000 1977 had a double pipe going straight out the back. You can loosen the tap rotate slightly and re tighten, maybe able to get a bit better clearance.
#4 PostAuthor: kev edwards » Fri Jul 20, 2012 6:00 pm
I'd say that was the wrong tap also.
KeithZ1R
#5 PostAuthor: KeithZ1R » Fri Jul 20, 2012 6:08 pm
looks like the carbs have dropped a bit from lack of support at the throat as well
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
t0ne
#6 PostAuthor: t0ne » Fri Jul 20, 2012 7:01 pm
Cheers chaps, I did wonder about the tap not being right. Unlikely then that I'll identify where the tap came from in order to get a repair kit for it.
Hinckley
#7 PostAuthor: Hinckley » Fri Jul 20, 2012 7:10 pm
Tap looks similar to the one on my 77 Ltd - my tap has two parallel outlets on the back.
I had somewhere near a 5mm gap between the lever and the carb, I seem to remember the tap was not exactly parallel to the tank edge - the gap between the tank and carb tops was not so big however mines running a standard air box set up.
#8 PostAuthor: z1bman » Fri Jul 20, 2012 7:34 pm
your tap is wrong it should have one outlet on the right side of the tap + the other pointing to no 4 carb. also check the front fuel tank mounting rubbers + the ones on the frame tubes
t0ne
#9 PostAuthor: t0ne » Fri Jul 20, 2012 8:55 pm
I think it's what's confused me is that it does look like the right tap from what little I've been able to see in service manual pictures but I'm glad I asked now before I shelled out on a repair kit and found it was useless.
Replacement taps seem a bit expensive though £75 on z-power :shock:
Z903
#10 PostAuthor: Z903 » Sat Jul 21, 2012 12:19 am
Tap looks correct to me? ( for z900) One pipe forward and one out the back as opposed to the Z1 which has two out the back.
As above...I'd have a look at the front tank rubbers? It's almost like the tank is to far forwards?
Padders
#11 PostAuthor: Padders » Sat Jul 21, 2012 5:42 am
Tap looks right to me for a KZ1000 Ltd but we seem to be in the minority here.
Steve Cooke
#12 PostAuthor: Steve Cooke » Sat Jul 21, 2012 7:16 am
The tap is correct, it'll be all down to the unsupported carbs, they've obviously dropped back quite away. Checking the tank rubbers isn't a bad shout though.
Slacken the inlet rubbers push the carbs in fully, hold them in and up and tighten fully and preferably fit a support bracket.
#13 PostAuthor: Pigford » Sat Jul 21, 2012 7:29 am
surely even if the tap isn't exactly "model correct", it's still gonna be in the same place :roll:
Z903
#14 PostAuthor: Z903 » Sat Jul 21, 2012 8:35 am
Pigford wrote:surely even if the tap isn't exactly "model correct", it's still gonna be in the same place :roll:
One would think so.
jimmock
#15 PostAuthor: jimmock » Sat Jul 21, 2012 6:03 pm
I take these engineering problems far too seriously.
Have you considered moving the engine forward in the frame??
Glad to have been of assistance.
Jimmock. :wnkr
I hate people I don't like !
