Z1 oil cooler
Z1 oil cooler
I discovered on the trip to germany that my Z1 does not like sitting in traffic.
general view seemed to be an oil cooler would help.
anyone got one for sale or can advise where to buy said item ?
not bothered about originality
thanks..................Chris
- z1000puddin
Chris,
Expensive one
http://www.ebay.com/itm/Kawasaki-FACTOR ... es&vxp=mtr
But there are plenty of Zephyr ones on ebay, some real cheap
Stu
Expensive one
Stu
Zed til Dead
- z1000puddin
chrisu wrote:that looks a good idea thanks.
do you know where to get the pipes & takeoffs ?
I get the 1/2 bsp cooler fittings and goodyear pipe (1/2" bore) off ebay and make my own takeoffs from billet or a cut down oil pressure switch (see my cafe racer project)
End up loosing the oil light though but i put a gauge in the gallery instead.
Will put up ebay links for the pipe etc later.
Chris, the cooler & lines on my 1170R came as a complete kit for a Renault Clio. I think most of these coolers are generic & just branded to suit.
This was a 'Mocal' and didn't take too much work to turn it into this;
There's something similar going cheap on ebay at the moment........
http://www.ebay.co.uk/itm/10-ROW-UNIVER ... 500wt_1361
Here's the goodyear hose.
http://www.ebay.co.uk/itm/290603815088? ... 1497.l2649
and cooler fittings,
http://www.ebay.co.uk/itm/400308676804? ... 1497.l2649
You should be able to do the whole cooler set up for around £100 and a bit of fabricating.
This is the same cooler, pipe and fittings as i used on the Drouin.
